clicking when turning
Old Apr 9, 2007 | 02:13 AM
SAudi's Avatar
Default clicking when turning
yet one more little issue i have to solve on my ar, when ever i turn in either direction i hear this weird cliking/ticking noise, it sounds like its coming from the left side but dont know what it can be, i still ahve to change the lower control arms on that side and thought they were the culprit but they seems good, i have a rear wheel bearing out on that side and never noticed anything before it went out, i also have had te car aligned and it dosent seems to pull but then again half the roads i drive to school are so turn up and at a slant i dont know. when im on good ground like say a mall parking lot everything seems fine, car turns, goes straight, a bit loaud because of the rear wheel bearing humming away and the annoying click/tick when turning. its not too loud or feeling dangerous but its just annoying me.anyone knwo what it is. i have a 1996 a4 quattro
Old Apr 9, 2007 | 01:19 PM
GIAudi's Avatar
Default RE: clicking when turning
Probably the CV joint. Not too tough to change especially if you are doing the control arms. Blauparts should have it for less thatn a hundred bucks. There is a DIY on Audiworld for a newer model but I'm sure it is similar.
Old Apr 9, 2007 | 02:23 PM
SAudi's Avatar
is there anyway i can jus tdump some grease into it without opening everything up since i have already changed my control arms and dont wanna spend another day or two taking everything off.
Old Apr 9, 2007 | 07:43 PM
GeilKyle2's Avatar
dumping grease in a worn cv isn't going to slove anything, grease cannot be used to replace worn parts
Old Apr 10, 2007 | 01:25 AM
GIAudi's Avatar
If it's clicking, it's shot. You shouldn't have to undo that much to get it taken care of.
Old Apr 10, 2007 | 01:28 AM
zrwhat's Avatar
once it starts clicking, its over
no fixing a worn ball bearing. its got a flat spot or two, and thats unrepairable.
go get a new joint. it sucks, but check it out, IT could TOTALLY be worse, you could own my audi! lol
Old Apr 10, 2007 | 12:50 PM
SAudi's Avatar
ownig your audi even with a bad engine could still be a good thing.just rebuild it up with forged internals and boost it like no other, then take it to town on mustangs.
Old Apr 10, 2007 | 07:42 PM
myaudi98's Avatar
Or you could do what i did and ignore the problem and then it snaps on the highway at 70mph. Not fun!
Old Apr 10, 2007 | 10:23 PM
zrwhat's Avatar
[:-] [sm=alcoholic.gif]
Old Apr 10, 2007 | 11:57 PM
myaudi98's Avatar
where do you get these crazy faces? lol
