Clutch Problems
Old Nov 17, 2006 | 01:11 PM
SamAdams's Avatar
Default Clutch Problems
I have a 2006 A4 2.0 with 25,000 miles. The clutch recently failed and the delaership said the clutch broke apart. Audi said this was caused by customer abuse but never could provide an example of how this could happen. After the clutch was replaced, we found a bad transmission synchronizer. What can cause a clutch to completely break apart?
Thanks
Old Nov 17, 2006 | 01:32 PM
techbod's Avatar
Default RE: Clutch Problems
customer abuse heheh that's an old one, clutch plate is covered by a warranty because its a consumable part BUT in your case ( they said it broke apart ) and this means a defective clutch and the fact its a 2006 with 25k on the clock the worst you could do is burn the clutch plate out not break it apart, they have to replace it
Old Nov 18, 2006 | 10:30 PM
dankhound's Avatar
If the clutch gets to hot the friction material can seperate from the backing plate causing it to break apart. Bad synchros are usually caused by repeated high rpm shifting.
phila19146
B8 Models
Dec 22, 2010 02:35 PM
pullacowonaski
Mar 27, 2009 12:00 PM
s4raf88
Jun 16, 2007 01:41 PM
SamJamaica
Jun 13, 2005 02:07 AM
