compression test
Old May 3, 2014 | 01:55 PM
magicturtle2's Avatar
Default compression test
If i have all the cams removed all of the valves should be closed right? Therefore doing a compression test without any belts installed or timing set should be fine right? Only the crank will turn over is my assumption.
Old May 4, 2014 | 11:50 AM
i'll answer my own question...no you cant do a compression test with all the valves closed. No air would be allowed into the cylinder for it to compress. You would get a vacuum in the cylinder if it was at TDC and pulled down, and you would get pressure if the piston were at the bottom of its stroke. A leak down test would work.
Old May 6, 2014 | 05:34 PM
Paul755's Avatar
Hi,
Do a leak down test. Each piston should be at TDC when you doe the test.
Old May 7, 2014 | 11:06 PM
I did the leak down test and the best reading I got was 80% leakage on one cylinder. The other 5 were all at least 90% leakage. Pulled the passenger side head and there is no visible mechanical damage to any of the valves but the carbon buildup on them is bad. Found a reputable machine shop that does Audis and will be taking the heads to them. Worst case..replace all valves and seals $500-$700 per head. Best case..clean, seat, and pressure test replacing a couple of vales here and there $80-$100 per head. He said unless the timing belt broke at speed it is unlikely I have major damage. Tomorrow I pull number 2 and Friday take them up and say a foxhole prayer!!
P.S The consolation is that I did not mess anything up with my blunder but rather discovered problems that would have resulted in catastrophic damage soon after changing the belt.
Old May 9, 2014 | 06:22 PM
Paul755's Avatar
cheapest place for Audi valves is Amazon. $10-12 each. Napa have the valve seals at about $1.40 each.
You probably should take a close look at the face on the lifter, the exhausts get pitted and damage the cam. I usually replace them all with INA units $300 or so if the motor is much above 60k miles.
Old May 9, 2014 | 10:32 PM
thanks for the tips. I will end up putting more money in this motor than I originally planned but I will have a nice car that runs well for under $3000. Not bad Id say.
then it will be time to customize!
DOC_DEPALMA
Oct 4, 2011 06:33 PM
DSMKiller
May 7, 2009 06:36 PM
Dallas09
May 1, 2009 04:41 PM
khj677turbo
Nov 21, 2007 11:15 PM
wood_e
Nov 7, 2006 06:35 PM
