Cranks but won't start, no spark
I have a 1997 Audi a4 Quattro 2.8L. It cranks but won't start. And gets absolutely no spark. I just put a new ignition control module in and still nothing. The person I bought it off of told me they over heated it and pulled over, let it cool down then drove it home and let it sit till she sold it. I've been playing with this car for a month now and can't figure it out. Can someone help????
first your engine speed sensor or crank sensor on the bottom of the motor right next to the engine oil cooler it's held in by 5 millimeter allen bolt.and then the cam sensor is on the side of the head closest to the firewall on the drivers side also held in by five millimeter bolts.if you don't have access to a lab scope you need to get a multimeter make sure your grounds are good on the sensors and also make sure you have signal voltage from each sensor to do that you're going to have somebody crank over the car and see if you're going to signal voltage end of each one I'm betting that its either your crank sensor or your cam sensor.
Vict0ar
04-03-2014 08:38 PM
kinnes042
S4
04-10-2013 06:29 PM
