CV joint problem
Old Mar 19, 2009 | 12:41 PM
SloRide's Avatar
Default CV joint problem
My 98 A4 has a bad cv joint on the front passanger side. If I grab the shaft, I can move it all over the place, so i know it's bad. The strange thing is that the car will not move at all. The engine runs good with no lights or codes when in park or netural. If i shift to drive or reverse there is a loud grinding noise coming from the engine bay in the cv shaft area. With that front wheel jacked up i can rotate it with lots of grinding. My question is can a competely blown cv joint cause the car not to drive the other 3 wheels?
Old Mar 19, 2009 | 12:44 PM
hcaudikeed's Avatar
yes. once one of the axles is disconnected from the tranny the way the diffs are designed will not allow the car to move. i suggest replacing your whole axle.
Old Mar 19, 2009 | 09:39 PM
SAudi's Avatar
yep, i you loose one wheel on a quattro your not going anywhere. best just replace the whole axle, its actually cheaper than replacing the joint. make sure you use new bolts. a few of us had our new axles fall off.
Old Mar 19, 2009 | 10:38 PM
ImTheDevil's Avatar
Yep, agreed with these guys. Don't try and rebuild the joint - it's way more hassle than just replacing the axle (and that way you get two new joints in the process).
Old Mar 20, 2009 | 02:30 PM
SloRide's Avatar
Yep, that's what I did. Replaced the whole shaft and bolts. Back on the road. Thanks for the replays.
jinsojoo
Nov 11, 2009 05:59 PM
RedShoeRider
Jul 10, 2009 01:38 AM
blackwat5r
Apr 17, 2009 02:56 PM
Dragon59
Apr 4, 2009 02:48 PM
drs305
Dec 14, 2007 06:05 PM
