Dead spot 2,000-3,000 rpms. 99 A4 1.8T
I have a 99 A4 Quattro 1.8T. Between 2000-3000 rpms there is a studder and doesn't really gain any power before 4000 rpms. Also when throttle is snapped in forward or reverse car stalls. Any ideas? It has a new throttle body,mass air,spark plugs,bov, and fuel filter. and plenty of fuel pressure.
Could be your throttle valve control module or my likly guess your throttle drive angle sensor. what could be happening is that your sensor contacts are worn out in that range from a lot of interstate driving. that metal wheres out and when it doesnt get a good signal the ecm doesnt know what to do
DV was shot on the first time then you replaced it with another problem "BOV" the Audi doesn't like that setup as the ECU rejects it like a broken limb, so all you did was replace a problem with a known problem- replace the DV
