drivers automatic window
okay, my driver's window used to go down and up automatically. now every window goes down automatically, the rear has to be rolled up manually(not one touch) and passenger's goes up automatically, but the driver's side doesn't go up automatically anymore! why not?! this really sucks? what could've happened?
RE: drivers automatic window
battery died...?
otherwise your master switch is defective.
the way to reset it after the battery died or was disconnected is to hold the switch until the window reaches the top and let go then immediately pull the switch to the up position
hold the switch up till the window reaches the top then let go and hold the switch up again for a few seconds, this reprograms the one touch feature.. do this for each window and you should be good afterwards.
