:: ECS Tuning :: DIY Brake Bleeding - Featuring Motive Power Bleeder.
Ever wanted to see a step by step procedure on how to bleed your brakes? Well now you have one at your convenience! Check it out below!!
*Featuring Motive Speed Bleeder* Jason |
With colder weather right around the corner it's always a good idea to make sure your brake system is in tip top shape! If you haven't flushed your fluid in the past 2 years it's probably a good idea!
While you're there give your lines, sensors, and other crucial components an inspection and replace any parts that show abnormal wear. Safe travels! Jason |
