engine cleaners
Old Apr 27, 2007 | 04:05 AM
ramses's Avatar
Default engine cleaners
I have a 2003 audi 4.2. There is a ticking noise comming from the engine specially after the car has been driven for 15 to 20 minutes. Showed the car to a few mechanics and still don't have a straight answer to what the problem is. Dealer is telling me it is normal. An independent shop told me its a oil pressure problem and advised me to use an engine cleaner. I used the MOTUL engine cleaner and oil change with the MOTUL 5/40 oil but the noise still there. It was better for a while. I have been told it should be done a couple of times before it really helps. The car has only 56 k miles on it. Any suggestions? Any other engine cleaner you guys recommend that would work better? I appriciate any advice you guys have for me.
Old Apr 27, 2007 | 06:22 PM
modset's Avatar
Default RE: engine cleaners
seafoam cleaner
Old Apr 27, 2007 | 11:13 PM
2k S4's Avatar
Put in a little heaver oil weight & see if it goes away. Some noise is normal.
Old May 2, 2007 | 07:21 PM
j4n3k's Avatar
The noise is probably coming from the valves. Slight noise is normal. I use slick 50 engine treatment it helps protect against friction and heat and is higly recommendet. The engine runs smother... So try it its not exspensive. were i live it cost around 22 eur. thats 50us- I think.
lazlo
Jun 16, 2012 12:20 PM
nexusgroove
Jan 5, 2011 12:10 PM
sollyd25
Jun 1, 2009 11:08 AM
Sky
Jul 30, 2007 05:14 PM
star
Jul 10, 2006 09:30 PM
