Audi 2.0 TFSI S LINE 2008
Hi I was wondering if anyone could help. My Audi is currently at 72,000 miles and seems to drive fine. The vagcom at the mechanics is giving the following fault codes.
Bank 1: system running lean on idle P2187 no signal/communication intermittent
Leak in air intake system P2279 lower limit reached
Evap purge control valve (n80) circuit open P0444 no signal/no communication intermittent
Turbo bypass valve control malfunction/open circuit P0033 no signal/no communication intermittent
solenoid valve (A) for boost presssure control N75 malfunction P0243 no signal/ no communication intermittent
fuel pressure regulator valve N276 open circuit P2294 no signal/no communication intermittent
we have checked car car for air leaks many times by spraying brake cleaner whilst idling and Air intake cleaner but there is no changes in the idle. Car is idling at 800rpm.
car is consuming quite a lot of petrol I get about 230-240 miles per full tank (city driving) which is about 60-65 litres of petrol equivalent to 13-14 gallons.
Further information.
Recently following has been replaced on car at 68,000 miles;
1. Timing chain
2. Timing chain tenioner
3. Water pump
4. Fuel pump guide
5. Drive belt
6. Rocker cover gasket
7. Oil dipstick lug faulty
8. Fuel cap
9. Pipe under manifold (not sure of name)
10. Timing belt pulley - was cracked upon inspection
cars service invertals were 8-10,000 miles up to 54,000. Thereafter I have serviced it fully at maximum every 8,000. All OEM parts have been used.
Whatever we have tried car engine warning light is appearing we clear it with va-com seems to reappear after couple of days sometimes in a week or two.
Its idle is little jittery but barely noticeable car starts and sounds okay. Usually engine light comes in once the engine temp has reached 90 degrees.
The vehicle is stage 1 remapped but these error codes where still showing without the remap. The reason for the large engine job was due to a failing rattling timing chain tensioner which is a common fault with these cars.
1. Timing chain
3. Water pump
4. Fuel pump guide
5. Drive belt
8. Fuel cap
steverothy
10-04-2012 10:55 AM
timecrisis2010
B8 Models
11-02-2011 01:35 PM
