Erratic boost pressure
Old Nov 24, 2007 | 05:58 PM
reg44reg's Avatar
Default Erratic boost pressure
Two days ago I went out and noticed something weird when I went from part throttle to little more than half throttle... If I laid into the throttle at any speed and any rpm the engine would stumble for a few seconds then pick back up at higher rpm. Shift, rpms would drop and it would do the same thing, would settle down but could still fell it stumbling after staying in it. Went out today and checked for codes and boost levels and leaks...no codes, no obvious leaks but my boost pressure was really erratic. Spiked to 21 then level off to 10-12, but would never be consistant.
Looking through the forums I see that a lot of people refer to the N75 valve could cause boost problems like this. Any ideas?
00 1.8t with K04 and GIAC
Old Nov 25, 2007 | 10:05 AM
ImTheDevil's Avatar
Default RE: Erratic boost pressure
Could be. Have you already upgraded your DV? I see you are chipped with a K04 - if your DV is stock, that could do it too.
Old Nov 25, 2007 | 12:00 PM
reg44reg's Avatar
Yes, DV has already been upgraded to Forge 007.
Old Nov 26, 2007 | 11:14 AM
patty AT forge's Avatar
Do the test outlined here:http://www.forgemotorsport.com/media/valve_service(1).pdf
And double check all of your hose connections...
trevor51590
Jul 22, 2009 09:52 AM
jbriancrout
Aug 12, 2008 11:19 PM
B5TurboA4
Jan 1, 2008 07:26 PM
ahgood
Mar 13, 2006 12:43 PM
y2karnival
Jan 29, 2006 01:54 AM
