Found it
Old Oct 9, 2005 | 07:12 PM
Bbarn's Avatar
Default Found it
Found it... Here is the instructions incase anyone ever needs it
# Turn on radio. The radio display shows "SAFE".
# Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
# Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
# Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
# The radio should unlock and be usable shortly afterwards.
# If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
# If you lose your radio code, contact your Audi dealer.
Old Oct 9, 2005 | 07:49 PM
cary12's Avatar
Default RE: Found it
Should have read this one first. I replied to the other post.
NickBroderick
Mar 28, 2010 12:13 PM
moeron7
May 15, 2008 11:48 PM
Palindari™
Mar 29, 2008 10:27 AM
225tt
Nov 5, 2007 08:15 PM
SAudi
Sep 26, 2006 01:30 AM
