Front tire vibrating when on the highway
Old Nov 30, 2007 | 11:28 AM
Deanne's Avatar
Default Front tire vibrating when on the highway
it's only the passenger side front tire...and it does this only when I am turning to the left, if I let off the gas the vibrating stops...it vibrates so hard it shakes my steering wheel and feels like the tire is about to fall off. any suggestions...tires are all pretty new
Old Nov 30, 2007 | 12:04 PM
SAudi's Avatar
Default RE: Front tire vibrating when on the highway
my first guess would have been the tires werent balanced but since you say theyre new im pretty sure they would have been, i had a similar problem and it turned out to be a worn out control arm ball joint, not saying that is defiently your problem but it would most likely be some ball joint compnent that is startin to go out. i would also check the wheel bearing since i know when their about to go out they have small amount of play and on a front suspension it can wreck havoc. best thing to suggest is just jack up the car on the side you think the issue is on and shake things, if you can feel play by shaking the wheel at 12 and 6 and again at 9 and 3 chances are its a wheel bearing. otherwise if its a suspension compnent you should see visible play in the worn piece. again these are just suggestions as to what may be wrong.
Old Nov 30, 2007 | 01:14 PM
2k S4's Avatar
Yea, bad balance, &/or bad suspension arms, usually TRE.
Boriqua1045
Dec 31, 2013 08:32 PM
Missyo90
Nov 19, 2013 08:38 AM
drwpepc
Oct 31, 2010 10:28 AM
audianthony
Jul 21, 2008 10:56 AM
shockedimpy
Dec 21, 2006 01:58 AM
