Is this a gear box Prob?
Old Nov 18, 2015 | 12:39 PM
sainy's Avatar
Default Is this a gear box Prob?
Hi Guys
I have an Audi 2002 automatic. I have a gear box issues I cant explain, please advice.
In traffic when I try move off, and accelerate, the car wont move, and then suddenly jump forward and drive, other times it stalls. On long trips it drives fine.
Any advice what Issues am I having?
Thanks
Harin
Old Nov 18, 2015 | 12:46 PM
dave944's Avatar
When it won't move, is the engine RPM increasing when you press the gas pedal? If the engine RPMs are not increasing when you press the gas, it's an engine problem, not a transmission problem.
Old Nov 22, 2015 | 02:51 PM
sainy's Avatar
Hi Dave
the engine rpm does move, thats why I try not press on the accelerator to hard.
The car eventually does move but its at every stop that this happens. Hope ou can guide me dave.
thanks
Old Nov 22, 2015 | 05:44 PM
dave944's Avatar
If the RPM's go up and the car doesn't move, it means the trans is slipping. Not good but it may be a fixable issue if they trans hasn't been damaged. I'd try a fluid and filter change on the transmission. It could be something as simple as being a little low on fluid or the filter is getting clogged and cannot flow enough fluid to the lock up the clutchpacks inside. I'd have a shop that deals with German cars (not necessarily the stealer...er...dealer) about doing fluid change. It may run couple of hundred dollars because the filter kit and fluid will run a $120 by itself.
curlyfrieS4
Dec 12, 2008 11:45 PM
alan93
Aug 13, 2008 06:03 PM
