Headlight HELP!!!
97 a4 2.8
My drivers side headlight is VERY dim (other side is fine). When I kick on the high beams the light goes out completely. I replaced with new bulb (H7) and it is still the same. Any suggestions???????????????? Ground??? Fuse??? Bad harness?? Relay?? Thanks |
RE: Headlight HELP!!!
Try swapping left and right parts, and see if the problem moves.
I get it back on thurs. I'll try it then. But exactly what parts are you taking about??
Relays.
Does it work now?
| All times are GMT -4. The time now is 09:53 AM. |
