Help please! 2012 Audi s4 misfire after 4000 rpms VAG COM POST
Hello, So this has been my issue the past few months. I have APR stage 2 (pulley, tune, and a CAI) I have taken it to the dealer and they cleared out all the carbon and changed 2 injectors but it didn't help at all. So here is my issue, when I accelerate and the rpms go over 4000 the EPC light will come out and cylinders will start misfiring (mainly cylinders 4,5, and 6). It then shuts down a cylinder and my car will spit and sputter until i turn it off for a few seconds and restart it. The EPC light does turn off after restarting but the engine light stays on. Here is what I got from my VAG COM (im a rookie with it). It wasnt always throwing this many codes it used to only be cylinders misfiring detected. I have installed new spark plugs, coil packs, MAF sensor, camshaft position sensor and the 2 injectors the dealer did (not sure which cylinders). any help would be GREATLY appreciated.
Thanks.
Sunday,13,September,2015,17:36:20:29595
VCDS Version: Release 14.10.2
Ross-Tech: Home
Address 01: Engine Labels: 06E-907-551-CAK.clb
Control Module Part Number: 8K0 907 551 D HW: 8K0 907 551 A
Component and/or Version: 3.0T SIMOS84 H08 0003
Software Coding: 0104000A240F0128
Work Shop Code: WSC 06324 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003 (AU48)
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 326B5EA0655CFAB1A8B-8067
7 Faults Found:
6353 - Cylinder 4
P0304 00 [236] - Misfire Detected
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 95237 km
Date: 2015.08.10
Time: 16:40:27
6355 - Cylinder 6
P0306 00 [236] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
6354 - Cylinder 5
P0305 00 [236] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
6371 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
6190 - Oxygen (Lambda) Sensor B2 S2
P0157 00 [032] - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 96724 km
Date: 2015.08.25
Time: 09:35:07
6095 - Catalyst System; Bank 2
P0430 00 [237] - Efficiency Below Threshold
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Mileage: 95269 km
Date: 2015.08.11
Time: 09:05:24
7948 - Cylinder Disabling
P130A 00 [044] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 23
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
Readiness: 0000 0000
Thanks.
Ross-Tech: Home
7 Faults Found:
6353 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 95237 km
Date: 2015.08.10
Time: 16:40:27
6355 - Cylinder 6
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
6354 - Cylinder 5
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 96724 km
Date: 2015.08.25
Time: 09:35:07
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Mileage: 95269 km
Date: 2015.08.11
Time: 09:05:24
P130A 00 [044] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 23
Mileage: 95236 km
Date: 2015.08.10
Time: 16:40:24
AteUrV8
05-20-2007 01:32 PM
pane2k
11-12-2006 03:25 AM
