how to use Launch X431 to reset service lamp and service interval set for Audi A6L
how to use Launch X431 to reset service lamp and service interval set for Audi A6L.
And here is a collection of Audi A6 Trouble Repair. Service Lamp Reset procedure: 1.Connect X-431, select [CAN BUS II DIAGNOSTIC CONNECTOR] connector; 2.Ignition ON; 3.Select Audi maker; 4.Select CAN bus system; 5.Access 17 Instrument cluster;; 6.Select 10 Adaptation,enter 02 channel, click OK; 7.Click “-”button to change the adaptation value into “0”, click OK; 8.Exit to end the reset. Set Interval procedure: 1.Connect X-431, select [CAN BUS II DIAGNOSTIC CONNECTOR] connector; 2.Ignition ON; 3.Select Audi maker; 4.Select CAN bus system; 5.Access 17 Instrument cluster; 6.Select 10 Adaptation,enter 40 channel, click OK; 7.Select “->” to enter the mileage interval for next service(e.g.: input 100 for 5000km, 100=(15000-5000)/100),click OK; 8.Exit to end the set. Note: Before change the interval mileage, please verify that the adaptation value in each channel Number: Channel “41” is “0”,channel “42” is “150”, channel “43” is “150” and channel “44” is“365”, otherwise, please modify it as above procedure. hope it help! |
| All times are GMT -4. The time now is 06:30 PM. |
