If you know your shit read this. Help is needed!
Old Dec 17, 2006 | 03:11 PM
jayrod0425's Avatar
Default If you know your **** read this. Help is needed!
I have a 2002 auto a4 18T. At low rpms the cars shutters like jumps in rpms. The car shitfts fine, i just had a tune up and got the check engine to clear then it just popped back up. The car runs fine its not lagging or anything just the rpm jumping. Has anyone had this problem or sound like sometihng they had please fill me in cause me and my mech are having some problems.
Old Dec 17, 2006 | 03:23 PM
techbod's Avatar
Default RE: If you know your **** read this. Help is needed!
what mods if any? did you have it checked for fault codes?? ( idle control valve )
Old Dec 17, 2006 | 03:31 PM
jayrod0425's Avatar
No mods at all. bone stock, trying to get the thing fixed before i mod it out
Old Dec 17, 2006 | 03:36 PM
techbod's Avatar
loose vacuum pipes/air leaks/IAC/throttle body clean out/air filter without codes I could go on much longer
Old Dec 17, 2006 | 04:02 PM
jayrod0425's Avatar
Just had the whole car looked at, the throttle body was cleaned and there was one vaccum line leak to the boost. after the tune up the car doesnt do it as bad ut still does. Havent looked at the iac yet. and it popped a sensor code it was replaced. this car seems to be a bottomless money pit!
Old Dec 17, 2006 | 04:07 PM
techbod's Avatar
bottomless money pit show me a pet that isn't if its your pride and joy the cost is immaterial
Old Dec 17, 2006 | 04:37 PM
jayrod0425's Avatar
yeah but when you dont have alot of it.......
Old Dec 17, 2006 | 04:50 PM
techbod's Avatar
my first car was a broken down mini Austin rover so I learned from the start you guys have more bucks so now you pay the penalty
Old Dec 17, 2006 | 06:16 PM
Baskin 4.2l's Avatar
Try getting a pressure tester. A pressure tester is a valuable tool on the turbo motors then get a vag com if you have not already. With these 2 tools you can help us help you and there is almost nothing you can diagnose
Old Dec 17, 2006 | 07:29 PM
Flip's Avatar
Is this at idle or when your driving too? Does it feel like a slipping clutch?
