IGNITION SWITCH STICKING
I have a a6 1995. The ignition switch sticks like it is binding a bit. When I start car I have to turn it back a bit so starter stops & all electrics work.. I sprayed with wd 40 & seems worse. My question is this the electric part that has the spring back in it or the cylinder I need to replace. Or any other ideas before my woman burns the starter out. She's not to fast turning it back enough. thanks guys.
RE: IGNITION SWITCH STICKING
Had similar problem in 95 Cabriolet. It was the switch and it does have the spring in it. About $45. Parts guy at Audi dealer claim this is happenning because of heavy key rings with alot of keys and junk on them. It was still just a bit sticky after replacement and would spring back appropriately, but I can tell that the steering interlock shaft is probably a bit worn. That would be a nightmare of a DIY job!
