KeyFob
KeyFob
Hi there,
Sorry if this has been asked a thousand times before but I have a 2004 A4 FSI SE. UK spec. One of my keyfobs stopped working the other day. i.e it would not unlock/lock the car. Went and got my spare remote and drove to work thinking it must be the battery in the other remote. Go and buy a panasonic cr2032 replacement battery and then replace in the faulty remote. I then follow the instructions from the manual which it says to do after replacing the battery in the remote:
Re-synchronising the remote control
- If the vehicle is locked, use the key to unlock the drivers door
- Press the unlock button on the remote control
- Insert the key into the ignition and switch on the ignition
- Switch off the ignition and remove the key
- Press the unlock or the lock button
I follow this to the letter and it does not work!! In fact I tried it for about 20-30mins!!!!
Has anyone any ideas? What am I doing wrong Is this a known issue?
Thanks in advance
TeK
Thanks in advance
TeK
A4BOYS1-8
07-13-2010 03:17 PM
