lifter noise
Old Sep 9, 2006 | 01:53 AM
CluTcH/B5's Avatar
Default lifter noise
yha im getting some valve/lifter noise.. am I screwed. Don't Audi have hydralic lifters. which means its time for a new head... or can I adjust them back to normal.
Old Sep 9, 2006 | 02:00 AM
CluTcH/B5's Avatar
Default RE: lifter noise
oh yha it's a 96 2.8 12v A4
Old Sep 16, 2006 | 04:05 PM
dankhound's Avatar
It may not need an entire head. You may just have a lifter that has bleed down and wont pump back up. If thats the case you would only need a new lifter. Pinpointing the exact lifter can be difficult. Youll need an automotive stethoscope to listen for exactgly where the noise is coming from. Then pull the vavlecover and inspect the lifters and head for damage. If the head isnt damaged, replace the lifter.
Old Sep 16, 2006 | 04:11 PM
techbod's Avatar
you cant adjust them, when did you do an oil and filter change?? what oil are you using??
Old Sep 17, 2006 | 01:14 AM
kakarot's Avatar
ORIGINAL: dankhound
Just new lifters. its easy to check them, all you need is wide screw driver and a like a blade or something to measure the size between the lifter and camshaft.
oh using new oil and or lower viscocity and synthetic.
HEC
B8 Models
Mar 5, 2014 01:40 PM
TSG
Aug 26, 2011 10:45 PM
audijsh2413
Jun 19, 2010 11:02 AM
brrman
Mar 21, 2007 06:42 AM
CluTcH/B5
Sep 19, 2006 05:10 AM
