Lighting / Grounding? / Brake Light Problem
Old Oct 31, 2014 | 10:36 AM
JoePatch's Avatar
Default Lighting / Grounding? / Brake Light Problem
I have a issue with a 2003 A8 that is kind of different.
The symptoms are:
When the headlights are off:
Light warning/ warning chime when I push the brake pedal.
Goes away after brakes are released. I did notice that the front running lights glow brigter when I push the pedal.
When the Headlights are on:
Unhappy Triad Condition - BRAKE LIGHT / EBS / ABS
Goes away after you restart the vehicle with the headlights out.
I think also that the Brake lights are dimmer than normal.
The Ross diagnostic tool reads a Brake Light Switch code, but drilling down deeper, I can see both poles of the switch
pulling in when I press the pedal
This sounds like a bad ground to me. Does that make sense?
Has anyone seen this one?
Does anyone know Where physically the lighting system grounded in this car?
Can this be caused by bad lamp connection(s) ?
Thanks for your help!!!
Joe
Old Nov 6, 2014 | 11:31 PM
AnthonySlaughter's Avatar
I just had the same problem ebs and abs would come on. So we replaced the brake light switch. Also there was one bulb going bad. It was out and when I went to take it out the light came back on. I left the bulb in and kept getting the brake light popping up. After 1 week of going crazy I decided to change that bulb that came back on. And it it solved the brake light problem. Sometimes audi are real sensative.
Old Feb 3, 2015 | 09:40 AM
JoePatch's Avatar
I found the problem!!
What happened is that one of the tail lights failed, sorta.
The brake light filament was shorted to the tail light filament, probably due to vibration over time. When the Tail light was tuned on, the +12 back fed into the line side of the brake light circuit, causing all of these weird symptoms.
It's always something weird like this that gets me.
Joe
luciddream42186
Jan 25, 2012 08:13 PM
m5racer
Aug 23, 2007 10:06 AM
smoovmusicdj
Aug 22, 2007 10:27 AM
2FAST4U
Aug 18, 2007 09:15 AM
drtymune
Jun 19, 2006 05:30 AM
