Loss of power, Idle drops at 1400rpm
I just replaced my left side cat and secondary o2 sensor after my flexpipe broke. I used a CT Converter and a Bosche universal 4 wire 02 sensor. Now that the work is done, The engine wants to stall at start and rpms drop once I get to 1400 rpm. Is the ecu tripped up,isthethrottle messed up or do I need to replace the primary sensor?
RE: Loss of power, Idle drops at 1400rpm
Have codes read and post them.
Car is a 99 b5 aha a4. code is
P1545 17953 Throttle position control malfunction. Is this a part that needs to be replaced, or can it be recalibrated? I know a bit about cars, but this is a little over my head. |
did you ever get the problem fixed im having the same problem
Wow I just posted the same thing having the same problem. Anyone???????
