Md state inspection FAILED my audi a4 1.8t rotor size.. need help
Old 08-19-2007, 12:56 PM
zamflip's Avatar
Default Md state inspection FAILED my audi a4 1.8t rotor size.. need help
Hi there,
I just bought a new 99 audi A4 1.8 quattro
Took it to md state inspection and found that they said my rear rotor - .279 and .290
Which, they said they should be .314...
Should i listen to them and change new rotors or are .279 and .290 normal and still alive for other miles?
or Should i try other different md state inspection location?
Need your opinions...
thanks
Old 08-19-2007, 01:03 PM
Default RE: Md state inspection FAILED my audi a4 1.8t rotor size.. need help
total crap I would think ( do they work or not ) do the breaks work?
Old 08-19-2007, 01:05 PM
zamflip's Avatar
Yes, the brakes work GREAT! no shaking or anything... i was like huh about must getting new rear rotors...
Old 08-19-2007, 01:10 PM
it could be the rotors are too thin due to wear ( not unreasonable )
Old 08-19-2007, 01:11 PM
zamflip's Avatar
Yeah? but do you know what size that shld pass? or fail? like .279 nd .290 is too thin?
Old 08-19-2007, 01:16 PM
Default RE: Md state inspection FAILED my Audi a4 1.8t rotor size.. need help
below 279mm is micro and if they work well its not a fail but if they are burned out then change them and the pads
Old 08-19-2007, 01:20 PM
zamflip's Avatar
Oh i see, many thanks... also, wondeering about whats rule of lowest mm that will fails? below .250 or what?
thanks
Old 08-19-2007, 01:25 PM
as a mechanic I have a cheat, the tester feels the edge of the rotor and if its high that signals break wear so if you grind that edge off the results are amazing
Old 08-19-2007, 01:31 PM
zamflip's Avatar
Oh, how ironically that they passed my brake pads but rotors naw... So, all i have to is get new rear rotors?
Old 08-19-2007, 05:40 PM
CRAZYHAWK's Avatar
The minimum rotor thickness is cast onto the disc.
Quick Reply: Md state inspection FAILED my audi a4 1.8t rotor size.. need help
