metallic rattling noise - need new long block?
my 2008 a3 2.0t (fwd) 6mt is making a metallic rattling noise. is there anyone out there who might be able to help? many thanks in advance. here are the details:
the car was bought new. it has ~5k on it, suburban traffic with mild-aggressive weekend driving (avg ~23.5 mpg, long drives low 30's). some WOT, but i was reasonable when breaking in for the first 3k. there's nothing extremely wrong with the way the car drives - i love it. handles fine. lots of power all over. the sound has no clear effect on performance. i'm running stock.
WHAT: recently i've noticed an intermittent metallic rattling/scraping noise. the sound is soft - i have to turn off the radio to hear it and other cars'sounds will drown it out. it's maybe like keys on a keychain but not as ping-like - more metal rustling/scraping. possibly like the infamous BB's in a can or little stones or something scraping/rattling around somewhere.
WHEN: it only happens when i dip gently into the throttle. i can most easily cause the sound by holding rpm at 1800 in neutral and dipping into the throttle to raise slowly to 2000-2200. i can also do it when rpm's are falling and i dip into the throttle to cushion the fall. clutch position doesn't change the sound. the car must be driven for 30-45 minutes for the sound to be possible. the sound happens in a range of weather conditions, though the car lives in the sf bay area.
WHERE: unknown. on two dealer visits, different mechanics localized the sound to under the hood. one said it could be a differential gear since the sound was loudest at one wheel well (i forget which). another said the problem was predetonation/knocking because he found that the sound got worse when he used fuel additive. however, i'm not sure this mechanic actually heard the noise i was describing - because in my opinion the noise wasn't worse after additive cleaned out the carbon.
MISC: fuel lines have been secured as per the service bulletin for 06-08 a3's. my dealer tweaked heat shields to no effect. they have also localized the noise to the "engine" with a "stethoscope." i think the noise began after the first check-up at 2.5k - got castrol syntec 5w40 and tire rotation. oil level is now stable near maximum. once before the check-up, some gravel got stuck somewhere (brake shield?) and caused metallic scraping/clanking (while moving) in the back of the car. resolved on its own. i crawled under the car and found no obvious gashes/dangling hardware.
currently, the dealer is offering to do a long block replacement (SCARY) based on the detonation/knocking hypothesis. though it's under warranty, to me this seems to be an extreme, last-ditch effort. i don't think i have detonation/knocking. i'd rather not get a new long block if i don't have to. what should i try first?
i've read the other forum threads about noises, but in the interests of soliciting the most unbiased readings of my situation, i'd prefer to avoid mentioning any specific possibilities of what the noise might be. would any of you be able to offer your advice?
thanks again.
p.s. anyone in the sf bay area know of a good audi mechanic? i'll be sticking with the dealer until my warranty runs out, but after that...
thanks again.
RE: metallic rattling noise - need new long block?
I haven't seen it occur in the a3 2.0 liter but I've had several 2.0 liter a4's with similar noises. Although they are not as intermittant as yours sounds they tend to be more noticable when the engine is at operating temp. What I've seen is the lobe on the camshaft that drives the high pressure fuel pump for the fsi system starts to prematurely wear and the play between the lobe of the cam and the fuel pump lifter causes a rattling noise (almost sounds like a diesel) might be worth looking in to before tearing the long block out...... good luck
Yes I have experience the same noise in my car for the last couple months, mostly noticeable in reverse or when I first start driving.
Lo-and-behold yesterday I lost all driving power in the car, no acceleration above 20 mph. Turns out geoff is right, I think.
My lobe's have worn and they need to replace the fuel cam shafts or something along those lines. 2300 is what the deal has quoted me at. I am looking around but hesitant to take it to someone else.
05 A4 with 65500 miles on it. Doesn't seem like something that should be happening in an audi given their reputation.
There must be more to it. I can't imagine he is getting a longblock warranty based on a guess. What did he say is causing the predetination. Cam lobes? Adjuster?
He may have found a cam problem but it has already worn your pistons.
brucelee
B7 Models
07-09-2008 07:30 PM
