My electrical Engine cooling fans don't shut off? Plz help
Its for an 1993 Audi 90s, my engine temperature is not even on 90, its half of that. I turn off my car and pull the keys out of the ignition and the fans are still running. I tryed reseting taking the battery out but it doesn want to turn off. plz help!!
RE: My electrical Engine cooling fans don't shut off? Plz help
actualy it just turned off after awhile. Is it maybe its to hot outside? Because my engine temp wasn't over 90. It never done that before. Do 1993 audi 90s cooling fans run after it was shut off and the car is locked? because i know some american and hondas electrical engine fans run after the car is shut off even when the key from ignition is out.
Sounds like your fan switch may be bad. Turning the fans on at too low of a temperature. You could however have a bad coolant temp sensor and your car may actually be hotter than its saying it is.
