NEED help with dead guages!!!
Old Feb 8, 2007 | 06:03 AM
2kblacks4's Avatar
Default NEED help with dead guages!!!
I have a 2000 s4 with 72000 miles with an APR 93 octane chip and have yet to replace my water pump or timing belt. I believe that my thermostat my have gone out. Both my oil temp and water temperature gauges are either bad or are not reading. Neither of the gauges works unless in the 4 or 5 minutes they read they are under demonic possession, but again this is sporadic and at random points during driving. In the next week or so I plan to take some course of action. Could the thermostat be stuck open? If so would that not cause the car to constantly run in warm up mode and cause terrible gas mileage? If so is it possible to change the thermo with out having to put the car up on a rack. All I have is jack and stands and being a poor college student that just replaced his clutch $2400 in all plus a few other things, I really don’t have much left over to pay out to a shop. I would prefer to do my work myself. Do you know of a good DIY post anywhere they would do a step by step lay out. Just a though but probably wrong. I was talking to my buddy and we thought that the fuses could of been bad, checked them an they were all good. Could there be an issue with any of the wires or other fuses for the instrument cluster up under the dash or just the instruments? The only reason I say this is that both of the gauges went out at the same time. I know that loose wires, touching wires or a bad connection or any combination of these could have caused this. If this is a possibility how could I check this? I have a digital multimeter but really would not know where to approach /start it on the car. I know how to take off the driver side knee bolster, but have no idea where I would go from there. Sorry, for all the questions. I am fairly new at this (especially with any electronic components or workings) and greatly appreciate your much needed help, any thoughts comments or advice would be greatly appreciated thank you!!! I have read that you can replace the coolant temp sensor for $5 and am planning on trying this. Where would be the best place to get one from -esc tuning has them for $20 is that fair? Do you think this could solve the whole problem?
Old Feb 8, 2007 | 06:32 AM
Rayman740's Avatar
Default RE: NEED help with dead guages!!!
Hi,
Read my thread titled *A4 Electric Windows and Odemeter..related? *. I reckon it is related to the processor inside the dashboard, and after checking the net discovered that temp and fuel gauges are common for this type of fault. U can try disconnecting the battery for 30min like I did when my guages were going crazy but the only other solution is a new/reconditioned dashboard unit
Pete
Old Feb 8, 2007 | 02:49 PM
2k S4's Avatar
Your post is really hard to read, if you in college, use some sentence structure.
Does the car feel sluggish at all? Any CEL light? Have you checked for stored codes?
The thermostat is behind the TB. So you would be doing a TB job to change out the thermostat.
Do you get heat? Do the gauges never move at all? Even if the thermostat is bad, the oil & coolant will go up over time.
Purchase or find some one local with a Vag-com, & purchase a Bentley Manual.
In the pic you see where the TB goes down under the throttle body? That is the water pump, over to the right of that is the thermostat.
MKE_Audi
Mar 23, 2012 02:20 PM
xfiles
Jan 23, 2010 07:57 PM
TBM
Feb 28, 2007 03:39 PM
2kblacks4
Feb 8, 2007 04:58 PM
Audi90C
Mar 30, 2006 01:55 AM
