New Problem - Help needed!
Old Aug 7, 2007 | 04:30 PM
beoperson's Avatar
Default New Problem - Help needed!
Just back from the shop where alternator was replaced along with spark plugs and wires.
When engine is warm I hear wobbling noise. I was censerned but decided to check it out later.
The other day battery light came on - the one that in the middle console - orange warning (not in speedo sectoin)
Voltmeter show little over 12V when engine is running. When starting engine battery is weak (Buttery cannot be bad - it was replaced few month back)
I was thinkingh perhaps alternator belt is not tight?
Any ideas suggestions?
Thank you
Old Aug 7, 2007 | 04:43 PM
techbod's Avatar
Default RE: New Problem - Help needed!
ill lean more to a bad ground wire or battery isn't holding a charge orr there is a voltage leak due to something like the audio or amp being on all the time draining the battery
Old Aug 8, 2007 | 09:29 AM
beoperson's Avatar
I have read the posts about battery leakage. Since it has been fine till now - can it be that after alternator replacement there is a problem with wiring?
FingerLakes
Sep 7, 2011 08:47 PM
TURBO_S2K
May 28, 2009 12:39 AM
Barust
Dec 1, 2006 10:15 AM
antoncole
Oct 6, 2006 02:31 PM
Fuzz
Dec 6, 2005 07:49 PM
