no communication with scanner
Old Dec 30, 2009 | 08:50 PM
bt2927's Avatar
Default no communication with scanner
we have a 99 a4 1.8t it has a check engine light so we went to have it scanned and have no communication with the scanner, checked the usual fuses, wires,even read that wiring an aftermarket stereo may be the cause, if anyone has had the same problem please let us know how you fixed it........thanx
Old Jan 14, 2010 | 01:21 PM
emmwhat's Avatar
Did you figure out what was wrong, I just bought a 2000 s4 and am having the same trouble.
Old Jan 15, 2010 | 07:30 AM
bt2927's Avatar
nope not yet.....will let you know when we do if you do the same.
Old Jan 16, 2010 | 05:29 AM
emmwhat's Avatar
I did some reading, looks like the "k-wire" goes from the OBD port through the stock radio and then into the ECU, I'm going to try and find the pin outs for the OBD connector and the ECU and just make a direct connection (next warm day), I'll let you know if that works. From what I've read, most of the problems we're having are due to a ripped / cut "k-wire"
antzb5s4
Apr 20, 2012 10:33 PM
Yann
Mar 16, 2012 08:30 AM
komish
Aug 15, 2011 04:17 PM
MidnightB5
Jun 5, 2010 04:47 PM
RedShoeRider
Nov 3, 2009 06:17 AM
