No heat in the car Help is so dam cold
ok the winter is here and im trying to turn the hetter on but it seems that no heat is comeing in. i looked under the dash and the litel motors are turneing to open it. The car runs fine the coolant hose is hot that goes in the car so does the out one. what can it be the problem???? are there any other things i have to check??? o and the fuse its ok. i just cant figure it out.
is your temp guage moving. you thermostat could be bad. if you hold it at like 2500 rpm and you get heat you probably have a flow problem somewhere. follow the hoses going to the heater core and see where it goes from hot to warm.
id check the heater control valve. it should be vacuum controlled. its under the cowl area. remove the plastic cowl trim and you'll see it where the two heater hoses go into the heater core. make sure your getting vacuum and the valve will hold vacuum itself.
