Oil Filter between M1-205 and M1-301?
I've been using synthetic oil since the first oil change and have changed the oil every 5,000 miles. The change to the larger M1-301 oil filter is good for the engine, but tight for me to install. Is there a filter with an outside diameter between the M1-205 (??mm) and the higher capacity M1-301 (93mm) that can be used on the 1.8T B5 engine?
