oil pressure light
Old Apr 21, 2012 | 12:55 PM
jamski1's Avatar
Default oil pressure light
just bought a6 cheap with 70000 on clock 2000 model.
oil pressure light come on took oil cap of see if it would splash out oil nothing.
any ideas,is it ok to drive
Old Apr 21, 2012 | 02:17 PM
Slowb5's Avatar
did you check the oil level?
Old Apr 21, 2012 | 07:40 PM
M5S5's Avatar
Tech Certified
More than likely the oil pick up tube is clogged causing oil starvation of the engine
Do not drive the car until it has been repaired!
Old Apr 23, 2012 | 05:13 AM
light8008's Avatar
Banned
hi, friend, do you checked the oil and it wad at the right level??? I think you need to have the actual oil pressure checked. It could be as simple as a bad oil pressure sensor, or ti could be a bad oil pump, bad bearings or a hundred other mechanical issues.
uobd2.com
Old Apr 23, 2012 | 09:22 AM
M5S5's Avatar
Tech Certified
uobd2.com
These cars are notorious for clogged oil pick up tubes caused by infrequent oil changes & wrong oil.
The oil pressure will have to be checked with a manual guage to be certain.
Idle spec is mininum 15-50 psi with engine at operating temperature , I believe at least 60 psi at 3000k rpm.
Dallas09
Aug 30, 2011 05:57 PM
ArmenB
Oct 11, 2008 12:23 PM
lfab500
Mar 3, 2007 01:33 AM
