p300,301,303 and misfire
I am getting check engine light with message p0300,p0301, and p0303. If I shift under 2500 rpm it drives fine. As I accelerate after that rpm range it sputters and the CEL flashes. When I easy off the throttle ir disappears. When I check with my scan tool those codes pop up. My car is a 2000 A4 1.8t front wheel drive with the ATW engine. Ionly have a K and N drop in and Apr Chip. I changed the plugs with Beru Ultra x plugs 27,179 miles ago. I will include a part from my repair doc.
Date Mileage Item changed 6/11/2008 165595 Pre-Cat O2 Sensor 9/9/2008 168362 A/C Belt 9/19/2008 168588 K&N Air Filter Cleaned 9/19/2008 168588 Replaced Wipers 9/30/2008 169126 New Stock Radio 10/11/2008 169479 Both Front Wheel bearings 10/19/2008 169562 Crank Position Sensor 10/19/2008 169562 Cam Positions Sensor 10/25/2008 169797 coolant temp sensor green My current mileage is 178,512. Any help would be appreciated |
Ever fix your problem?
