Q7 glowplug help - desperately needed
Please help!!! I have an Audi Q7 3.0 tdi s-line quattro I up my foot down on the highway. At high speed the glow plug light went on and the car went into limp mode. I stopped and restarted the engine but every time I put my foot down, it did the same thing. Audi specialist garage ran a diagnostic and bought up the following error: 5211 - Fuel rail/system pressure p0087 00 [096] - too low Intermittent - not confirmed - tested since memory clear Freeze frame Fault status 000000001 Fault priority 2 Fault frequency 1 Mileage 43k I said I’d take it in a couple of days later to the specialist. Next day the car started to jerk like fuel wasn’t going through. Then it completely cut out and wouldn’t start. specialist is completely out of ideas. I’d really appreciated some support here please. its been with the garage now for a month. They’ve changed injectors and tested the following without success: High pressure pump Low pressure pump Injectors High pressure switch Low pressure switch Diesel filter Diesel temperature sensor Injector fuel line They’ve also checked the tank to make sure no pressure is being lost there I’d really appreciate any help here Thanks |
