Radio antenna
Recently purchased a 2000 A6 fitted with a Bose radio system. FM band seems to work fine, however, the AM band emits anly static. No vivible antenna. Where is the antenna located. Suggestion?
Thank you in advance Mick Sarasota/St Louis 2000 A6 1986 560 SL |
RE: Radio antenna
amplifier is in the D pillar driver rear where most of the audio stuff is
RE: Radio antenna
The anteanna is located in the rear glass. However as mentioned above you have an issue with the amplifyer for the antenna and not the actual antenna itself.
| All times are GMT -4. The time now is 04:08 AM. |
