Replacement of both up-stream Lambda sensors A8
Old Dec 18, 2006 | 07:02 PM
rupz's Avatar
Default Replacement of both up-stream Lambda sensors A8
Hello I need some technical help regarding the replacement of both up-stream Lambda sensors fitted to my 2001 3.7 A8. It doesn’t look like these much room… The Audi workshop manual suggests the CAT with sensor attached needs to be removed first to replace either up-stream probe. Is this really necessary? Do I need any special tools? Reason for changing both Lambda probes, I keep getting “Internal Resistance to high” intermittently on either, bringing on dashboard engine management warning light. Thanks for any help Rgds, Lee
Old Dec 18, 2006 | 07:12 PM
techbod's Avatar
Default RE: Replacement of both up-stream Lambda sensors A8
before you go tearing it apart what was the codes you got to determine which o2 sensor is bad??
Old Dec 19, 2006 | 06:59 PM
rupz's Avatar
Hi Dave,
I'm getting codes:
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent.
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent.
When looking forward under the car is B1 Left Hand and B2 Right Hand?
Thanks Lee
Hanzo
B8 Models
Aug 11, 2017 06:35 AM
fusionknight
B8 Models
Jan 17, 2012 02:54 PM
PeterCain0110
Jun 7, 2011 03:09 PM
kennyk
Dec 10, 2009 06:20 AM
kakarot
Mar 23, 2006 12:07 AM
