Replacing ABS Sensor
Old Jan 2, 2008 | 02:17 PM
trevor51590's Avatar
Default Replacing ABS Sensor
I want to pull my right rear ABS sensor to check out the wire. It appears that the wire goes up into the underside of the car somewhere. Where does it go to? I want to check the connection of the wire and see if that there are any breaks or anything that could make it not read/throw a code. I have searched tech articles and everything and can't seem to find anything about this.
Thanks,
Trevor
Old Jan 13, 2008 | 12:47 PM
dankhound's Avatar
Default RE: Replacing ABS Sensor
If memory serves me correct it goes under the back seat. There should be a connector there for it.
Old Jan 13, 2008 | 08:52 PM
SAudi's Avatar
correct, under the back seat, 100% for pre face lift and about 95% sure for post.
Old Jan 13, 2008 | 10:20 PM
WolfsA62.8Q's Avatar
Main reason for sensor light coming on is bad sensor or the connection right at the wheel.
kaden420
Nov 23, 2010 04:45 PM
Zipper
May 25, 2009 12:23 AM
TommyGunns
Oct 9, 2008 12:20 PM
audi_a4_2003
Jan 1, 2008 03:14 PM
jj2345
Aug 23, 2007 06:44 PM
