running problems '97 adr 1.8 A4
Old Mar 28, 2008 | 05:09 PM
doncornholeio's Avatar
Default running problems '97 adr 1.8 A4
Greetings
I have a problem with my A4 [:@]
1. Year of car 1997
2. Model of carA4 1.8
3. What engine & TIP or 6spADR
4. Miles car = 140k engine = 85k (cam belt tensioner bolt snapped @ 120,500miles (500 miles after 120k service) fitted used replacement ADR engine (mileage on replacement engine70k)
5. FWD or Quattrofwd
6. Any CELs or stored codes (not that i know of)
this is what happens
start car (engine starts as normal)
but stops straight away
start car (with a tiny dab on gas pedal) to keep it running, take foot off gas and revs drop quickly and stops
engine sounds normal
drive off , for about 15mins need to dab gas if stationary or revs drop and engine stops
after 15mins (roughly) when clutch is applied, revs go up and fluctuatesfrom 3,000 to4,000rpm (up then down , up then down)
what i have done
air filter (new)
airflow meter (new)
throttle body (clean)
injectors (clean)
plugs (new)
oil(new)
oil filter (new)
adjusted throttle cable to its max (in an effort to keep engine running) (not a fix i know but this has started to do my head in lol)
so, thats my car, thats what it does, and thats what i have done.
If anyone has any suggestions on how i can fix this problem
i would be most gratefull
Kind regards
Tony
Old Mar 29, 2008 | 09:41 AM
CRAZYHAWK's Avatar
Default RE: running problems '97 adr 1.8 A4
Go to AutoZone and have them check for hidden codes.
tremotorsports
Aug 2, 2013 07:37 PM
barnard
Mar 6, 2011 10:33 AM
pmkcolorado
Jun 17, 2009 02:44 PM
audicoupe89
Oct 15, 2008 01:19 PM
willistexas
Apr 15, 2005 01:15 AM
