S4 power door locks quit
Old Nov 18, 2007 | 12:35 PM
rightsandlefts's Avatar
Default S4 power door locks quit
2000 S4 Power Door locks including keyless remote, drivers button lock/unlock quit working. Remote doesn't even get the horn beep or lights to flash. Any ideas?
Old Nov 19, 2007 | 11:52 PM
ashezplayboy's Avatar
Default RE: S4 power door locks quit
Push the buttons and go to the trunk i have an a4 an in the trunk on the right side behind the panel is the motor for my locks it should have two blackskinny hoses that go into the locking motor. they might have just came loose. but before u go in the trunk turn ur car on an make sure it works manually with the buttons on the door. if they work then it just might be the batteries in ur key, go to radio shack and buy two new batteries and sync the locking mechanism.
Old Nov 20, 2007 | 01:18 AM
Thanks for the info. Do you have to pull the entire side panel off to get at it from inside the trunk? I checked the fuses #6 and twenty something, andthey were fine.I listened for the pump/vacuum to operate when I pushed the unlock button but nothing.
Old Nov 20, 2007 | 01:29 PM
2k S4's Avatar
The battery in the remote might be dead. I would start there.
reprograming the remote
http://www.audiworld.com/tech/misc13.shtml
Old Nov 20, 2007 | 05:50 PM
Door button doesn't work either. Manually unlocking the doors from the drivers key won't lock/unlock the rest of the doors.
Old Nov 20, 2007 | 06:08 PM
2k S4's Avatar
ORIGINAL: rightsandlefts
You can Vag-com it for codes on the locking system. You might also want to check the fuses. You may just have a dead door lock pump, it's in the trunk on the passenger side.
Old Nov 20, 2007 | 06:41 PM
I'm in NE Tacoma - you know any shops that don't charge to much to plug it in around here?
Old Nov 20, 2007 | 06:47 PM
2k S4's Avatar
No sorry, I go over to Redmond & Seattle for car work. I do have a Vag-com, but don't have much time this week, maybe on the weekend I can help you out.
Old Nov 20, 2007 | 06:52 PM
Right on, I'll tinker with it over the holiday and let you know how far I get. Thanks for the offer.
The Bishop
Feb 24, 2008 09:40 PM
Henley
Aug 31, 2007 11:39 PM
skidplatexa4
Apr 12, 2005 05:49 PM
Shaunp05
Mar 12, 2005 01:17 AM
