Service Due Comes On
Hello All, my wife's '08 A6 Service due comes on when she starts the car and then goes off in a second or two. The oil was changed less than 2k miles ago although that was more than a year ago. I should mention that it's a '08 with only 44k miles on it.
How do I reset?
Thank you.
How do I reset?
Thank you.
If your car is like my 2013,a scan tool is needed for a service reset. For oil change only,a reset can be done using the dash *****,but the procedure is described so confusingly that I have not been able to make it work. Also,the owner's manual says that a battery disconnect will zero the display,then later says that the service interval values are retained. I think that my manual was translated from German to English by someone who was not a native speaker in either language.
If you have an owner's manual,look up "Service interval display" in the index and see what the reset procedures are.
