Spark knock?
Old Jan 8, 2008 | 05:46 AM
90sMoneypit's Avatar
Default Spark knock?
I have a 93 90s with intermitent spark knock. Usually when the engine is under heavy stress (3000rpms or climbing a hill). The plugs are newish (although they look like they have been dipped in ashes on the bottom but they are dry) I haven't changed the wires and I have been using 92 or higher octane fuel. So what do I need to do to fix the knock? thanks for the help.
Old Jan 8, 2008 | 08:05 PM
sepp's Avatar
Default RE: Spark knock?
Can you confirm that the plugs in the car are the reccomended type, and temprature?
Yes, it's a stupid question, but I've seen this happen.
Old Jan 8, 2008 | 10:57 PM
ImTheDevil's Avatar
Make sure they're gapped correctly too - another problem area that could cause you issues.
Old Jan 9, 2008 | 12:19 AM
boostedB6's Avatar
if the wires are still original i would definitely do that. i don't know off the top of my head, but that car has a distributer right? I would assume so. Replace the cap and rotor too. the ash look on the plugs is carbon. commonly caused by a rich fuel condition or oil burning. Chances are its from a weak spark. Inspect the inside of the dist. cap. and the rotorif you see any corrosion on the terminal contacts or burn marks between the contacts replace it. If there is burn marks between the contacts your spark is jumping. this was very common on mkII andmkIII vw's with the 2.0. Hope that helps you. post a little more info after checkin it out. I'll help in any way I can.
Old Jan 9, 2008 | 09:57 AM
Ok I have a 93 90s the engine has no cap it has a coil. I can't gap the plugs since they are already gapped from the manufacturer NGK. Any suggestions on a good plug? Someone told me NGK's and then bosch platnium 4's and I tried both and no difference at all but then again I know the wires have to be changed and maybe even the coil pack? I just want to get this car running great! I mean it does but without noises and creeks and what not it's a great running car and I plan on keeping it till it falls apart so I'm not concerened with spending money on it. Could it be that the plugs are to tight? My check engine light keeps coming on and goes off when I turn the car off and I believe the two are related. Thanks for all the help guys!
Old Jan 14, 2008 | 07:21 PM
boostedB6's Avatar
i would find out what the check engine light is coming onfor. what engine is in the car? give me the code from the cel and the engine code (8thvin digit)and i can lookup more info for you
PoloBLK
May 29, 2011 12:46 PM
vlado182000
Jul 16, 2010 03:20 AM
B5Bobby
Aug 8, 2008 01:50 AM
ARIaudiS4
Jul 29, 2008 12:51 PM
diehlryan
May 27, 2007 12:52 PM
