Temp gauge
Old Jun 14, 2011 | 10:00 AM
spacer's Avatar
Originally Posted by audiaubrey
i changed it within 3 months ago. but i will definitely try it again! thank you for the suggestion. i do not have an oil pressure or temp guage..just electronic display that will show an icon if the oil level is low. i need to buy some and install them...
Oh you already changed the sensor? Well then it's the thermostat. You start by changing that sensor and if that doesn't fix the problem next step in the stat.
Old Jun 14, 2011 | 01:54 PM
tdepirro's Avatar
I am having a similar issue with a 2001 1.8t. Where is the sensor located? Does anyone have a picture?
Old Jun 15, 2011 | 02:16 PM
spacer's Avatar
Here is an excellent, easy to use guide mate:
http://www.audiworld.com/tech/eng47.shtml
There are two colours of sensor so make sure you get the right one for your car. There are a green and blue one and can be picked up for around a fiver and £12 repectively on ebay.
The chances are the problem is the thermostat but it will do no harm to rule this our first and as I say it only costs a few pound and takes 10 mins.
You will loose coolant but if you're quick enough you won't lose that much. I avoid putting water in the coolant tank and always use 50/50 coolant but what I did was top the tank up with water (after losing some changing the sensor) and took the car out for a spin to see if that solved the problem as either way I was going to change the coolant anyway. When I noticed that it didn't help I went and bought coolant and ordered the stat from ebay, changed the stat and flushed the system and all is well now.
It is very easy to do so if the sensor doesn't work for you let me know and I'll link the guide for changing the stat.
Here are links to the sensors on ebay: The blue one is £12 and is what I needed to for a 98 1.8T
Green
http://cgi.ebay.co.uk/AUDI-COOLANT-T...item27b45c0d88
Blue
http://cgi.ebay.co.uk/AUDI-COOLANT-T...item27b45c0d8a
Here is the link for the thermostat:
http://cgi.ebay.co.uk/AUDI-A4-A6-1-9...item4cf4fd064a
Old Jun 15, 2011 | 05:06 PM
audiaubrey's Avatar
well i have changed thermostat, water pump, and ect sensor.. maybe the upgraded intercooler in the front is just preventing alot of airflow and therefore the fans behind the intercooler are only able to push hot air onto the engine.blahh
zedea
Jan 18, 2013 03:11 PM
Russell2686
Jul 8, 2009 11:55 AM
dhillon
Feb 23, 2009 07:14 PM
theTTkid
Nov 7, 2007 05:52 AM
dtcoastguard
Jan 24, 2007 10:42 PM
