Tie Rod Question
Old Dec 1, 2005 | 05:24 PM
Lancaster's Avatar
Default Tie Rod Question
Hey gang, have a question/issue with my local Audi/Porche service department.
I went in today for a few minor fixes (running light out, oil change). And after waiting about 2 hours, the service guy and the mechanic take me out back and try to show me that the steering tie rods are worn down and need to be replaced. The mechanic grabs the wheel (on both sides) and shows that it's wobbly and loose, and the rods must be replaced otherwise it could be very dangerous to drive with. I admit, the wheels didn't look very solid when he was jerking em around, but the car drives just fine! It doesn't pull one way other the other, I don't have any bad vibrations, and my tires aren't wearing abnormally. The car is old, 1997 A4 2.8 Quattro, but it only has 55k miles on it...which were very easy miles to boot.
So getting to my question...Does this sound like a legitimate wear n' tear part that need replacing at 55k miles...despite no noticable allignment miscues or steering problems? Is it a part that could be fixed maybe instead of replaced? And if not, is this possibly something I could replace myself if I bought the parts? They quoted me $75 per tie rod; so $150 plus labor comes out to like $400! =O If the worst is true and they need to be replaced, please somebody tell me I don't have to let Audi do it >< Any guides perhaps?
Thanks
Old Dec 1, 2005 | 06:31 PM
jukeit's Avatar
Default RE: Tie Rod Question
Sounds like they definitely need to be replaced. The ball joint is probably bad and can't be repaired; you will need to purchase new tie rod ENDS. There is a difference between the tie rod and the tie rod end.
At 80,000 miles, my car didn't have noticeable problems until I was on a rutted road. The combined effect of the ruts and the bad tie rod ends would toss my car from one side of the lane to the other depending on how I hit the ruts. I would also feel the problem at speeds over 60 mph in turns.
I did the replacement myself. Aside from oil changes and spark plug changes, it was the first repair I did on my vehicle. It was not difficult. Here is a write up on how to do it.
http://www.audiworld.com/tech/wheel29.shtml
Old Dec 1, 2005 | 08:09 PM
Lancaster's Avatar
awesome, thanks for the help
Old Dec 1, 2005 | 10:08 PM
tlstyle's Avatar
tie rods are pretty easy to do yourself if they are not frozen but make sure you got get an alignment after your done or you will eat your tires up real quick.
Old Dec 3, 2005 | 03:34 PM
sandman's Avatar
yes this is one of the most common things to go on our cars. do it your self its easy...
theres a writeup on www.audiworld.com
Old Dec 18, 2005 | 03:01 AM
Dj Spiel's Avatar
I did my tierods in August. It's not that hard. 2 hours max gets some friends easier
ORIGINAL: Lancaster
Thanks
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
