Timing set?
Timing set?
I have a 96 A4 with the 2.8 that I am installing a used engine in. I replaced all the timing belt stuff, seals, gaskets etc while on the engine stand. I had to rotate the passenger side cam about 1 notch in order for the cam lock tool to line up. After completing I turned the engine over a couple of times and everything seems ok. Do I assume the timing is set correct and all is well since the cam lock tool was used? If not what can I do?
Audiguruforyou
09-20-2011 01:31 AM
