transmission issue?
dont really know what this is so im posting in general tech. have a 2005 a4 3.0 6 speed with just over 100k. when i was driving today i heard a weird rattle noise that i couldnt pinpoint where it was coming from(i said it was coming from the front and my friend said it sounded like under the car). it occurred in first gear at just over 3000 rpms and very slightly in 2nd under the same load. i pulled over to see if the noise still happened when i was in nuetral but nothing. anyone have this problem before or an idea what it could be. is my first gear on its way out? also no difference in drivability that i can notice. any help is very much appreciated
Could be a loose heat shield under the car. There are several that provide heat protect from the exhaust. Sometimes they might loosen up a little and cause a rattle.
Originally Posted by dave944
(Post 1498392)
Check the transmission and motor mounts. If one of those is shot, it could be causing some metal to metal coming together under a load (acceleration, deceleration). If it's in neutral, there is not a lot of flex in the drivetrain to cause loading.
