turn signal wont work...
03 A4 3.0
Turn signal on pass. side doesnt work i have changed the bulb three times. dont know where the relay is to change it. Flashers flash normal minus the front p/s turn signal not flashing... any help would be appreciated!!! Thanks, Anthony |
You might have a bad flasher relay. Have also seen signal switches causing weird problems.
Might actually have to check for voltage. |
