VAG Codes
Old May 12, 2008 | 12:49 AM
shearder's Avatar
Default VAG Codes
Ok Before i start, i bought this VAG-COM thing and it seems to work a charm - BUT - it appears the software is ONLY shareware and i need to register it. When i want to scan it gives me hell about registering. So what now? Is there anything useful about it when it is shareware?
Another question, i did a test on the alarm (Immobilizer) system as it appears not to be activating. Everything seems to check out ok. But where do i see if it is activated? Also, when i try to check settings i need to register. So i guess this is somewhat short of useless?
I got a code from the engine - how do i read it so i know what needs to be sorted out:Saturday, 10 May 2008, 16:41:37
__________________________________________________ _____
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4A0 907 473 H
Component and/or Version: 2,6l V6 MPFI AT D03
Software Coding: 00087
Work Shop Code: WSC 01333
1 Fault Found:
00533 - Idle Speed Regulation
10-10 - Adaptation Limit Not Reached - Intermittent
Control Module Part Number: 8LO 862 257
Component and/or Version: ZV-Pumpe, DWA, Funk D03
Software Coding: 14190
Work Shop Code: WSC 01479
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
01374 - Shareware Version. To Decode all DTCs
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Shareware Version. To Decode all DTCs
__________________________________________________ _____________________
Thanks in advance.
Old May 12, 2008 | 10:19 AM
zippy_gg's Avatar
Default RE: VAG Codes
With the shareware version I was able to re-program my tiptronic so it won't shift into 2nd without me telling it to.
You can also clear a CEL.
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
