VAG Codes- Makes no sense to me
Old 04-26-2015, 12:09 PM
tomattsi's Avatar
Default VAG Codes- Makes no sense to me
Here is what I pulled just after a no start when temperature outside is cold :
Thursday,23,April,2015,13:51:16:40868
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Ross-Tech: Home
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 BQ
Component: 2.8L V6/5V G 0001
Coding: 07251
Shop #: WSC 63351
VCID: 73E514D0412A8CB963D-5140
8 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
P1118 - 35-10 - Open Circuit - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
17834 - EVAP Purge Valve (N80)
P1426 - 35-10 - Open Circuit - Intermittent
16690 - Cylinder 6
P0306 - 35-10 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 AT
Component: AG5 01V 2.8l5V USA 3132
Coding: 00002
Shop #: WSC 63351
VCID: 7F0DC8E07D62D8D9175-5140
1 Fault Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C371F6C8C3463C1927-5140
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
VCID: 2D51C2A8E78E9A49F59-25A8
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 63351
VCID: 3A7BF9F426C03DF160B-5140
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 QX
Component: B5-KOMBIINSTR. VDO D13
Coding: 02262
Shop #: WSC 02608
VCID: 11297E585BF6DEA9F11-5140
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
VCID: 408F8B1C401C67212EF-4EB4
2 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
VCID: 60CF6B9CE0DC07210EF-4B1E
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
VCID: 65C17A88FFFE6209FD9-517C
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 63351
VCID: 2447278CB4445B012A7-4B1E
End-------------------------(Elapsed Time: 04:11)--------------------------
Here is after clearing, and still no start:
I pulled the cable for the oil sensor to verify that it was working.
Thursday,23,April,2015,14:31:15:40868
Ross-Tech: Home
Coding: 07251
Shop #: WSC 63351
Readiness: 0110 1101
Coding: 00002
Shop #: WSC 63351
VCID: 7F0DC8E07D62D8D9175-5124
Shop #: BB 24334
VCID: 1C371F6C8C3463C1927-5124
Coding: 00160
Shop #: WSC 63351
Coding: 00304
Shop #: WSC 63351
1 Fault Found:
Coding: 02262
Shop #: WSC 02608
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
Coding: 16140
Shop #: WSC 63351
VCID: 408F8B1C401C67212EF-4ED0
2 Faults Found:
35-00 - -
Coding: 00101
Shop #: WSC 63351
VCID: 60CF6B9CE0DC07210EF-4B04
Coding: 00012
Shop #: WSC 63351
VCID: 65C17A88FFFE6209FD9-5198
Coding: 00110
Shop #: WSC 63351
VCID: 2447278CB4445B012A7-4B36
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End-------------------------(Elapsed Time: 03:48)--------------------------
I hope I am posting this right, never tried it before.
This code will change again if I clear and start over.
What sensor is keeping the car from running in cold? I have changed so many things already based on what everyone thinks it is that I will have a new car pretty soon with changed parts ;-)
Any help would be very appreciated.
A4TOTT
03-05-2010 11:54 AM
PseudoKirby
04-28-2008 04:16 PM
darkoceanblue
10-18-2007 11:29 AM
Armenian
06-29-2007 12:26 AM
twenty8red
04-08-2007 03:01 AM
Quick Reply: VAG Codes- Makes no sense to me
