vag com question
vag com question
at the measuring block screen - engine-
the first bank 001. it shows the temperature of what... the temp goes from -20c to 100c in a second. and where can i find more instructions to use that dan thing...it looks like chinese writing =/
RE: vag com question
If you look RIGHT under the reading it tells you what it is measuring. It should coolant temp.
http://www.ross-tech.com/vag-com/tour/m-blocks.html
READ here to learn how to use it
http://www.ross-tech.com/vag-com/tour/main_screen.html
cool...i dont have the same thing cuz it dosnt say coolant...only temperature.. is it normal for it to go from -40 to 100c.?......the sensor is brand new... another question...on the 12 v there is a sensor on top of the air box with 2 plugs... is it the intake air temperature sensor??
ORIGINAL: a4BRZLowrider
akitamike
06-09-2008 11:05 AM
SouthernAudi
10-14-2007 06:47 PM
