very cool boost and a/f gauges on S4
<img border="0" src= "http://members.cox.net/shokwave/audis4gauges/completedash.JPG></P> <img border="0" src= "http://members.cox.net/shokwave/audis4gauges/tachinstalled.JPG></P> </P> |
Those are hot, I want some.
they are custom so u can get that for your A4, its gonna be pointless cause the turbo doesnt blow that much boost
[Deleted]
[Deleted by Admins]
its not mine, i just found the picture
the gauge faces on the S4 are slightly different (more greyish compared to the black of the A4). Also if you have a pre 2000 A4 you have the analog clock so this may not work or at the least, would requiresome extra fabrication.</P> And don't worry about the numbers going to 20 psi...Once you chip you should see a hold of 15psi and spikes up to 17/18 depending on the chip. If you have a 2001 1.8T with the X chip (like myself) you will see a constant hold of 18-20psi--which is awfully high--Also if you get a k04 kit installed, most of them make around 18psi too. The PES T28 kit and APR stage 3 both make about 20-23psi at full blast...</P> |
thats pretty clean! i like it, too bad i have a TT.
